youthy's bus 30 to 75 in fourth 2.1td multi valve
Water Cooled Conversions, Kitcars Or Special Vehicles Here
Postby famous phil » Tue Mar 02, 2010 1:12 am
:D well its took some time but youthy has uploaded a video I think this is great and will make many a smile seeing what were up to now and then ,, he did a run in his bus down a slight gradient 3rd into 4th gear then back up in 4th for return run ,
how van pulls this is rolling in third gear and into 4th gear
This is from 30mph in 4th gear only , speedo reads exactly correct with sat nav
phil 07703 844035 t25 spares
too many campers , 1 t25 with peugeot 1.9 dturbo sport engine ,Darlington camper parts
famous phil
Postby COVIN » Tue Mar 02, 2010 9:19 am
That pulls like a train Phil, nice one 8)
That engine looks right at home in there, so another good conversion mate, any idea what it's like on fuel etc yet ?
Postby tintin » Tue Mar 02, 2010 11:09 am
Now that's a fast wedge! :shock: 8) 8)
tintin
Postby Scott-Westy » Tue Mar 02, 2010 11:52 am
got any T25s for sale Phil - I know a couple after a good un.
Postby famous phil » Tue Mar 02, 2010 11:53 pm
:D Hi all ,we dropped 10 t25 gearboxes off to get some checked over with a hope of getting a couple back with high ratios , my bus is not to bad as works out same ratio as an AAP box ,, MPG is good on a long steady run but with anything this size floor it to make it shift like this then will drop to high 20s low 30s
I've been tuning mine and was running 23PSI for a short while while setting it up in the wet going strait was spinning in third 8) then altered the fuel boosting but went the wrong way without relizing so not getting enough fuel at the moment , will have it sorted by the weekend for a vid now we know how :roll:
we've got one with a 1.9d peugeot engine we bought in unfinished project LHD very little rust but has its fare share of dings and maybe brush painted , we've a few jobs to get out the way first before this , and I might be selling my own one as might build myself another diesel its all hush hush at the moment
famous phil
Postby youthy giblets!!! » Tue Jun 15, 2010 9:50 pm
i usuallly get about 35mpg at 75mph but i am a bit rough with if im honest but it seems to like it just wants to pull
There arent enough days in the weekend
youthy giblets!!!
Return to Modified Or Specials
