356
Water Cooled Conversions, Kitcars Or Special Vehicles Here
Postby ray 356 » Wed May 19, 2010 5:57 pm
ray 356
Postby steve9bugg » Wed May 19, 2010 6:08 pm
8) 8) 8) 8) :P :P :P :P :P :P NICE
MANX PROWLER BUGGY/BAJA BUG
BODYWORK, PAINT, NEW & PART WORN TYRES, WELDING, MECHANICAL & VINYL CUT GRAPHICS. UNIT C, SIMPSON STREET SUNDERLAND, SR4 6DR.
Tel: 0191 5672080 Tel: 07716030669
www.spcgarageservices.co.uk - Image - www.spcgarageservices.co.uk
steve9bugg
Postby The Lockkeeper » Wed May 19, 2010 7:45 pm
That looks absolutely class. Give me it :D
Postby ray 356 » Wed May 19, 2010 8:39 pm
ray 356
Postby coops » Wed May 19, 2010 10:27 pm
Looks like it needs a set of wings on it !! bet its a flyer. ( that would be aeroplane wings ) :) 8)
Cheers Coops
1963 Mantaray Beach Buggy
1972 VW Beetle
coops
Postby ray 356 » Thu May 20, 2010 7:10 am
euros you can get hold of a Porsche 356 very special. Il testo reca poche informazioni sulla genesi di questo particolare esemplare, nato a partire da una 356 Coupé del 1955: si accenna solo al fatto che l'investimento per crearla è stato molto ingente. The text bears little information on the genesis of this particular model, born from a 356 Coupé of 1955: it refers only to the fact that the investment to create it was very significant. Pare, inoltre, che la vettura, equipaggiata con un motore 6 cilindri boxer 3 litri di provenienza Porsche sia molto, molto veloce. It seems also that the car equipped with a 6-cylinder boxer engine of 3 liters from Porsche is much, much faster.
La somiglianza è netta con i primi prototipi degli anni Trenta elaborati da Ferdinand Porsche e destinati a confluire nella Porsche 356 n.1: la Tipo 64 e la Tipo 64K10. The resemblance is clear with the first prototypes of the thirties developed by Ferdinand Porsche and designed to meet the Porsche 356 # 1: the Type 64 and Type 64K10.
ray 356
Postby ray 356 » Thu May 20, 2010 7:46 am
Wildly Modified 356A with Hot Rod 3.0L 6-Clynder 1955 Porsche Silver Bullett Hot Rod s/n 54156 Silver with Bare Aluminum and Green Leather Interior This car is a stunning and totally unique one-off that subscribes loosely to the 356 Outlaw philosophy. Based on a 914-6 chassis, this car has been fitted with a mid-mounted 3-litre 911 engine with Weber carburetors, as well as a 915 5-speed gearbox. It was built by Australian Jeff Dutton in 1992. The body is based on a 356 Continental from 1955, and is recognizably such up to the B-pillar. The roof has been chopped several inches, as is fairly standard for an `Outlaw`, but thanks to the mid engine placement and 914-6 chassis, the wheelbase is longer than that of a 356. Consequently, the car displays a dramatic and striking `fastback` rear treatment, which is beautifully set off by a number of very neat and extraordinary details. The philosophy throughout the car is one of lightness and strength, and much of the car is structurally composed of a tube frame. There is an integral roll bar, which is in keeping with the general interior aesthetic of Spartan functionality. The disc wheels are 17 inches in diameter and are highly polished to match a number of other accents on the car, including the 718 RSK style side vents, driver`s side mirror, as well as the engine and transmission access covers. The panels themselves have been extensively louvred to allow heat to escape. The beehive tail lamps from the 1955 Continental have been retained, and no fewer than six polished exhaust tips fitted, to hint at the 6-cylinder powerplant. A racing style through-hood fuel filler has been fitted at the front, while the rear view and passenger side mirror both operate on the `periscope` principle through view windows that have been let into the body panels. The result is very coherent and nothing short of incredible. The exterior has been recently repainted to a nice standard and shows only a handful of small blemishes. The metal trim is very nice, including the highly polished accent panels. The lights and lenses are excellent, including Hella H4 headlamps. The interior is quite Spartan but still feels very special. The green leather bucket seats are attractive and comfortable, while the dished wood-rimmed steering wheel with Porsche crest is very much in keeping the 1950`s racer feel of the car. The dashboard provides a similar effect and has been carried over from the Continental, complete with large `Telefunken` radio speaker aperture. The instrumentation is by timeless VDO instruments, some of which have been sourced from a 911. There is no carpeting or other upholstery to speak of, while the door panels are nothing more than polished stamped aluminum panels. The windscreen and side windows are Plexiglas, as is the rear porthole, which provides a great view of the engine, and an okay view of the scenery behind the car through the louvers. Also of note is an access panel between the seat backs on the rear firewall, cheekily labeled as an emergency exit using a sticker from an airliner. Between the seats is the exposed shifter for the 915 gearbox, as well as the ignition panel, complete with protective red switch cover for ignition, starter button, and an ominous red indicator light. The general condition is tidy, with no significant wear. The leather is excellent, as is the upholstered headliner. The engine compartment is clean and looks like any backwards 911 engine should. It is not detailed for show but is satisfyingly clean, and brightened up by chromed air filter rain guards and polished trim. The engine itself has been built to RS specifications topped with Weber carburetors and is claimed to make 279hp. The front compartment reveals a fuel cell, as well as more evidence of the tubular frame components. The brakes are hugely impressive fully ventilated and drilled discs from a 934(!), which capably slow this extremely rapid car. Perhaps the most unique and creative of the 356 Outlaw breed, this car is stunning in every respect, and totally unique. Combining the balance of the 914-6 chassis, reliability and potency of the 911SC driveline, aesthetic feel of the 356, and development and rigidity of a tube-frame car, this car really represents the best of all worlds. The level of detail is remarkable and its construction was an uncompromising and hugely expensive endeavor. This is a completely unrepeatable car that has had hundreds of thousands invested and is truly a one of a kind, head turning, tire burning Porsche hot rod that can be enjoyed on the street.
FJ612
Petrol 5 speed
Sold on the 18.05.2010
ray 356
Postby famous phil » Thu May 20, 2010 10:41 am
:D Ray nice find a GRP replica of that would be 8)
phil 07703 844035 t25 spares
too many campers , 1 t25 with peugeot 1.9 dturbo sport engine ,Darlington camper parts
famous phil
Return to Modified Or Specials
