Vauxhall Corsa Electric powering steering to T25 camper
Water Cooled Conversions, Kitcars Or Special Vehicles Here
Postby youthy giblets!!! » Tue Jun 15, 2010 10:05 pm
Been on with this today , all measured up and made just need to weld fixing brackets up and reasemble but ran out of gas so just spotted at the moment hopefully will have gas tommorow evening to finish off. Once welded up and bolted into place can see if bottom vauxhall U.J's need any alteration but think they be somewhere near
[img][img]http://i145.photobucket.com/albums/r218/youthygiblets/philspics208.jpg[/img][/img]
This is all origional vw on the top end so standard stalks, ignition switch, steering lock, steering wheel etc all work as factory fitment still need control module for vauxhall eps brain just not sure which to go for yet basic one £40
Last edited by youthy giblets!!! on Sat Jun 26, 2010 9:09 pm, edited 1 time in total.
There arent enough days in the weekend
youthy giblets!!!
Postby youthy giblets!!! » Wed Jun 23, 2010 9:26 pm
Bit of an update, got a few bits welded up at local machine shop as i didnt have enough time to get gas due to work commitments. The guy that i took it to fits these to E-Type Jags and couldnt believe how well it works on T25's as it took him hours of head scratching to get E-type set up correct.
Bought controller of ebay just opted for manual adjustment type for now which works fine and i couldnt believe how much more of a pleasure to drive it makes the Bus having never had one with power steering :D :D
will upload some pics of finished article soon
I would advise anyone with a T25 to fit one of these its almost like driving a different vehicle
youthy giblets!!!
Postby ray 356 » Wed Jun 23, 2010 10:40 pm
nice one m8, andys is ready 4 his now :D should be in for test 2morrow :wink:
ray 356
Postby famous phil » Thu Jun 24, 2010 8:43 am
:D I think this will work great for Andy as you can adjust the sensitivity , youthy popped round to see if you were at the workshop yesterday evening but did not say if you were , I had a drive round and the first thing I thought was Youthy's lass will be able to drive it now :D
phil 07703 844035 t25 spares
too many campers , 1 t25 with peugeot 1.9 dturbo sport engine ,Darlington camper parts
famous phil
Postby ray 356 » Sat Jun 26, 2010 8:06 am
:shock: :shock: wow what a difference, how light it is on steering :shock: , watch out i can see your lass twoking your bus now :lol:,
think wayne retro should have one of these with his 18s on:D,
youth do you think this can be done for a bay and a split :wink:
ray 356
Postby famous phil » Sat Jun 26, 2010 8:48 am
:) would think can be fitted to bays n splits OK , I've already been asked to design one for a split :)
famous phil
Postby maddison » Wed Jul 21, 2010 6:43 am
i`m collecting the parts for a split one at the moment....not power tho..just a rack
bedford rascal rack t25 bezel box (not sure if thats actually requred...may be able to go straight from the column into the rack
the rascal rack then attaches onto the central steering arm on one end and the bezel box the other....but dont see why you couldnt use that electronical shizmo above in place of the column if you wanted it, as you have the t25 bezel box
you can use an astra rack if you wanna do a away with the central arm completely...but i`m toying with airbagged beam at some point so the rascal set up allows this, the astra rack would get in the way
http://dubenhams.com/
maddison
Postby famous phil » Sun Jul 25, 2010 9:16 pm
:? will you end up with this = turn steering left and the bus will go right :?: if you use the type 25 relay box , is it not possible to connect the column strait to the sooty rack :?:
famous phil
Return to Modified Or Specials
