re-map or superchip
Water Cooled Conversions, Kitcars Or Special Vehicles Here
Postby rambo26 » Fri May 23, 2008 9:43 pm
is there much difference in having your car re-mapped or fitting a superchip two it
rambo26
Postby COVIN » Fri May 23, 2008 10:49 pm
A lot depends on the type of system but a re-map will usually only release so much power where as another chip should give more when complimented with other modifications to fuel system and boost control :wink:
Postby rambo26 » Fri May 23, 2008 11:16 pm
whats the best chip 2 go 4
rambo26
Postby COVIN » Sat May 24, 2008 7:35 am
I'm not sure what's the best one for the modern VW turbo engines m8 I'm old school VDub and most of my Turbo experience is with RWD cars like Ford with Cosworth engines.
Just remember that with FWD vehicles, to much power will make it a pig to drive so I'd pick one that isn't to wild or cause turbo lag etc.
You'd be better off with a chip that gives a mild tune right across the rev range and generally improves the cars performance and drive rather than one that will give a boat load of power at certain revs.
Postby sima » Sat May 24, 2008 9:15 am
As far as I see it you have the 2 options. The superchip is a pre programmed chip that is designed to alter timing, boost fuel and air etc. The other is a re-map which involves making the alterations to your vehicalon a rolling road. This must be the better option as every engine is slightly different and you are tweaking your engine and comparing the results as you do it. This may be a bit simplistic but seems to be true.
If you are looking for a place to do it there used to be a rally prep place on the opposite side of the road to Maiden law hospital in Durham (Just allong from Lanchester). When I had my 205 gti he was the b*llocks
Hope this helps
Getting there..... Slowly!!
sima
Postby phill » Sat May 24, 2008 6:01 pm
there's only 1 chip id use for vdubs & its REVO got a nebie thats revo'd up & its running 231BHP
when revo do it they set it up with the laptop too so you get the best performace
phill
Postby rambo26 » Sat May 24, 2008 10:20 pm
how much and where do i gat revo chip from
rambo26
Postby phill » Mon May 26, 2008 6:33 pm
the chips about £450-£500ish maybe cheaper if its cable & not fly by wire throttle.
i got mine done in darlington albet hill ind estate at the MK4 golf center
th e guys called allen fishburn.
think there maybe 1 near newcastle.
phill
Postby rambo26 » Mon May 26, 2008 7:02 pm
spoke to the lad i bought the car off and he told me it has a revo map done thats why its running 190bhp
rambo26
Postby ray 356 » Tue May 27, 2008 5:23 pm
phill wrote:the chips about £450-£500ish maybe cheaper if its cable & not fly by wire throttle.
nice guy Alan I'm getting his fabricating tool when he retires
ray 356
Return to Modified Or Specials
