getting out of vw sale
Items, Parts & Vehicles For Sale
Postby topolino » Tue Apr 04, 2017 2:34 pm
as I have sold all my vws(still physically have a car but its sold) what I have left is completely all new parts rebuilt around 100 miles ago stock 1600 twinport engine, good for bug, bus,ghia, new ali case ,crank,recon rods ,pistons and barrels,bearings oil pump,heads,carb,intake tinware,dynamo, coil,leads,flywheel,clutch,all up was running in one of my cars but car was sold minus engine, has heat exchangers and new exhaust, super strong with the aluminium case, even has fresh oil in engine, just bolt in and go , all for £1,400, cant build on a used case for this money, also have most of a 1200 engine stripped all clean parts, good case crank rods new pistons and barrels, cam and lifters,heads,tinware, flywheel,intake ,new carb and new exhaust all for £150.
topolino
Postby mawsy » Wed Jun 21, 2017 5:55 pm
What will you take for the 1600 engine, just had one throw a rod and chew up the crank and case give me a call on07716029349 cheers Mawsy
maintainance plumbing stops you biting your nails and picking your nose
mawsy
Postby mawsy » Thu Jun 22, 2017 7:33 pm
Reference my last post cancel inquiry engine being sourced by others cheers Mawsy
mawsy
Return to For Sale
