5x112 15" BRM Alloy Wheels
Items, Parts & Vehicles For Sale
Postby MartyMcFly » Sun Jun 04, 2017 3:04 pm
I have swapped to steels on my panel van.
Up for grabs are a set of BRM 15s.
I think they are 15x6J et35 - but my measurements could be wrong, and nothing stamped on rear of rim.
They have some pretty harsh corrosion to the polished areas as pictured, definitely in need of a refurb.
205/50/15s all round - 2 recent tyres in good condition, 2 quite poor and could do with replacing.
Came off a 72 crossover, running an 8mm spacer at the rear, down 2 splines, with no rubbing issues.
Located in Consett - £150?
MartyMcFly
Postby sargeantmillar » Tue Jun 06, 2017 6:43 am
Marty,
What's the centre bore size at the rear ?
"I'm a shark fighting, virgin tamer .............. Lost a few, but only to the sharks !!!! RIP Paul Ray 1973-1999
If it ain't broke, then slam it. That'll cause you some problems
They used to say life begins at 40, but life is what you make it. Life is too short. Don't wait until you're 40 to enjoy it. Go for it and never look back.
sargeantmillar
Postby MartyMcFly » Tue Jun 06, 2017 9:04 am
Hello mate!
Not much help but It's at least 66.6
Will have a measure when I'm home Thurs/Fri.
MartyMcFly
Postby MartyMcFly » Fri Jun 09, 2017 9:12 am
Measured 66.6 Thought they would have been bigger but apparently not.
Hope this helps.
MartyMcFly
Postby MartyMcFly » Sat Jun 10, 2017 12:19 pm
Just to update this...
Paul had a measure up against his BRMs and these look like 5.5J not 6.
That has thrown my offset measurment out aswell, and not sure what the ET actually is now, possibly ET25?
MartyMcFly
Return to For Sale
