Garage and workshop clearout
Items, Parts & Vehicles For Sale
Postby dustrat » Wed Jun 21, 2017 7:27 pm
I've got a few things for sale as having a clear out.
6 Ton press that I bought last year to do a job but have only used it once and as new. Cost me £65 will accept £45 ovno
Starter modul for starting engine out of car. Bell housing complete with starter motor. is fitted with key for starting and also oil pressure warning light £60
Also no photo's at moment but have reconditioned 1600cc twin port long block with following spec
AS41 AE type case. This a type 1 case.
Case has been line bored 1mm OS and thrust is 20.5mm
Barrels and pistons are not new but are as good as , new piston rings fitted.
Genuine standard VW crankshaft that has been crack tested and polished
All new bearings
Engle 110 camshaft kit
Heavy duty oil pump
Alloy cranshaft pulley with deg settings
Flywheel for 200mm clutch
Heads have been tested for cracks and have had new valve guides,valves and heavy duty valve springs as well as new Scat steel push rods.
Some tin wear that has been blasted and powder coated to go with engine.
Alloy rocker covers .
End play set at 007mm
£950 ovno
Every thing has been set at factory spec so is as new
Robert
Image Image Image
dustrat
Postby dustrat » Wed Jun 21, 2017 9:13 pm
Starter module sold. :D
Robert
Image Image Image
dustrat
Postby dustrat » Thu Jun 22, 2017 8:09 am
Can deliver press with-in 15 mile radius. Going to Cramlington next Wednesday.
Robert
Image Image Image
dustrat
Postby dustrat » Thu Jun 22, 2017 8:30 pm
Press now sold. :D
Robert
Image Image Image
dustrat
Postby sargeantmillar » Thu Jun 22, 2017 9:27 pm
ImPRESSive :rolf:
"I'm a shark fighting, virgin tamer .............. Lost a few, but only to the sharks !!!! RIP Paul Ray 1973-1999
If it ain't broke, then slam it. That'll cause you some problems
They used to say life begins at 40, but life is what you make it. Life is too short. Don't wait until you're 40 to enjoy it. Go for it and never look back.
sargeantmillar
Return to For Sale
  • Users browsing this forum: No registered users and 3 guests
