Tdi engine conversion for Bay / T25
Items, Parts & Vehicles For Sale
Postby sargeantmillar » Sat Feb 10, 2018 1:38 pm
Change of plans means I’ve got the following that I will be selling soon.
VW 1.9tdi AFN engine
VW 012.301.103 WW010 5 speed gearbox
Full wiring loom including ecu
Porsche GT3 radiator
Standard turbo as well as a VNT20 Turbo
VW T25 JX wedge sump
Came from an 80k car. Bought it from a well known fella off SSVC so have no reason to doubt it’s not genuine.
Cheap way to get 130-160 bhp in a bus
Need to shift it fast. Cost £500 plus £70 for the sump.
Make me an offer
"I'm a shark fighting, virgin tamer .............. Lost a few, but only to the sharks !!!! RIP Paul Ray 1973-1999
If it ain't broke, then slam it. That'll cause you some problems
They used to say life begins at 40, but life is what you make it. Life is too short. Don't wait until you're 40 to enjoy it. Go for it and never look back.
sargeantmillar
Postby WebbA » Wed Feb 14, 2018 7:50 pm
What's involved in getting it to fit in an early bay?
Lowered cars are for Bum Burglars :D
WebbA
Postby sargeantmillar » Wed Feb 14, 2018 9:26 pm
Depends on your gearbox choice.
If you use your bus box then you’ll need an adapter plate from someone like ultimate engineering or mv engineering. Pretty straight forward but You’ll obviously need to make some engine brackets and wiring alterations. JustPaul used a Land Rover throttle body to do away with the fly by wire accelerator set up. Then there’s just fitting the rad somewhere and plumbing it up.
If you use the Passat box then it needs flipping so you don’t end up with 5 reverse gears. A few more brackets and some adjustments to the gear linkage. But you get a gearbox that can handle the power and 5 gears
Simples :lol:
There’s lots on tindernet about this and similar conversions.
sargeantmillar
Return to For Sale
  • Users browsing this forum: No registered users and 3 guests
